Clone different objects to new Layer
ikua
Post by ikua » Tue Feb 06, 2024 6:26 pm
Hello!
I want to highlight some object on a layer, with another layer pushed in the background. I try now to make a clone form all entities and move them to layer one. Unfourtunatly this only works for polylines until now. I am not able to use "castToShap" for RTextEntities or block. Maybe someone has an hint:
var appWin = EAction.getMainWindow();
	appWin.handleUserMessage("Neubau mit Farbe hinterlegen")
	var doc = this.getDocument();
	var di = this.getDocumentInterface();
	var op = new RAddObjectsOperation();
    var ids  = doc.queryAllEntities();
	var ids_lays  = doc.queryAllLayers();
	var newItm;
	var sh;
	var itm;
	for (var i=0; i<ids_lays.length; i++) {
		var id_lay = ids_lays[i];
		akt_layer = doc.queryLayer(id_lay);
		if ( akt_layer.getName().indexOf("Neubau ...") != -1 )  { //nur Neubau Layer
			var layer_entities =doc.queryLayerEntities(id_lay,true)
			doc.setCurrentLayer("0")
			 var copied_entityee = layer_entities.clone()
			for (var k=0; k<layer_entities.length; k++) {
				appWin.handleUserMessage(akt_layer.getName())
				var itm = doc.queryEntity(layer_entities[k]).clone();
				 if (isPolylineEntity(itm)) {
					 appWin.handleUserMessage("Polyline")
					 appWin.handleUserMessage(layer_entities[k].toString())
					sh = itm.castToShape();
					newItm = shapeToEntity(doc, sh.clone());
					appWin.handleUserMessage(isEntity(newItm).toString());
					op.addObject(newItm,false);
				 }else{
					 appWin.handleUserMessage("keine Polyline")
					 newItm = doc.queryEntity(layer_entities[k]).clone();
					 // newItm =shapeToEntity(newItm);
					 op.addObject(newItm,false,true);
				// appWin.handleUserMessage(newItm.toString())
				di.applyOperation(op);
	appWin.handleUserMessage("sdf")
Re: Clone different objects to new Layer
Post by andrew » Tue Feb 06, 2024 8:55 pm
We don't need to go convert to a shape as indeed not all entities have a shape representation.
You can simply query the entity, clone it and re-add it to a different layer. I'd also do it in one single operation:
var sh;
var itm;
            itm.setLayerName("0");
            op.addObject(itm,false,true);
Post by CVH » Wed Feb 07, 2024 5:46 am
I have my reserves about:
First, Layers are meant to group things that should display alike, print alike.
If you want that more clearer, highlighted, then common practice is to adapt the layer(s) attributes.
Second, there is no layer in the background, no drawing order based on layers.
Don't look at CAD layers as stacked planes to draw on, they are listed in alphanumerical order.
The drawing order is a property defined per entity.
Newly created entities always receive a drawing order one higher as what already exist.
Meaning that they end up in the foreground Instead of the background.
Remark that in both code sections all the intended entities are duplicated on the standard layer '0'.
Including entities intended for Blocks.
Wondering for what var ids = doc.queryAllEntities(); is used.
ikua
Post by ikua » Wed Feb 07, 2024 8:53 am
How the hack!!!
Thanks @Andrew. Maybe i was in a code blurry. Tried out so many things, nothings seemed to work. Thanks for the hint.
@CVH:
The wohle reason is, i am developing tools to create PID schemes in a comfortable way. We are working often with existing structures and implement new parts. So i have layers with sublayer for the old as for the new part (sulayer such as "water", "gas", "sludge" ...). The layer have different colors (e.g. water blue). Now i wanted to hightlight the new parts but still keep the information (color) of the substance. So i clone all entities to a new layer, give them drawOrder one. This layer has a big linewight so i can different the old from the new easily. See foto.
and on more: var ids = doc.queryAllEntities(); isnt used. It was a copy of fragment copy paste.
Other question:
like I said, i am developing tools for pids (https://en.wikipedia.org/wiki/Piping_an ... on_diagram). You can see with my questions until now, that my knowledge of coding is quite limited. Nevertheless i think my tools are quite handy (automatic Pipe naming in the scheme, get a list of all used components togehter with the layer, hightlighting new parts :-)). I think i will go on working on that. How is the best way to share that tools, and to involve other people? Github??
greets and thanks for your fast replies
Screenshot 2024-02-07 084642.jpg (46.66 KiB) Viewed 873 times
Post by CVH » Wed Feb 07, 2024 9:42 am
This is clearer, the code snippets did not alter the order ... :wink:
Remark that the drawing order is zero based and negative values can exist in the current session.
A recent post on this: https://www.qcad.org/rsforum/viewtopic. ... 506#p43496
Your code does not work for TTF based text, you might want to consider the usage of CXF based because that is line-art.
