QCAD Python Visual scripring with Sverchok and Blender
ionut
Post by ionut » Tue Jan 21, 2025 12:30 pm
What I am trying to do is basicaly this:
- create a live link between Sverchok and QCad.
This could be easy to do with a watchdog, that can be activated somehow with a checkbox.
Here is an example of reading a dxf file opened in QCad and creating 3D geometry in Blender.
Next - I will showcase the reverse.
https://www.youtube.com/watch?v=UBH8zfMW7o0
Question:
- on windows 11, it is possible to do with a javascript script to call somehow the revert function with a trigger outside qcad?
Re: QCAD Python Visual scripring with Sverchok and Blender
Post by andrew » Tue Jan 21, 2025 3:46 pm
If QCAD is running, you can load additional files or run a script by launching it again with the appropriate parameters:
For example, to trigger the revert menu, you can launch:
qcad.exe -exec scripts/Pro/File/RevertFile/RevertFile.js
A more sophisticated solution would involve QFileSystemWatcher.
ionut
Post by ionut » Wed Jan 22, 2025 8:19 am
Thank you!
I will use the simple aproach!
I will come back with feedback if/how I've solved it.
ionut
Post by ionut » Tue Feb 11, 2025 9:22 am
Thank you for the tip! This code does the trick for me in python.
I've realised I don't need a live update.
But I can use a watchdog to do it if I would find it more conveninent.
import subprocess
# Set up the paths
qcad_path = "C:\\Users\.......\\Downloads\\qcad-3.31.2-pro-win64\\qcad-3.31.2-pro-win64\\qcad.exe" # Path to the exe
dxf_file = "model_export.dxf"
# The Revert comamnd
command = [qcad_path, "-exec", "scripts/Pro/File/RevertFile/RevertFile.js"]
# Run the comand
subprocess.run(command)
print("The DXF file has been reset in QCAD.")
