Refresh a widget
RR88
Refresh a widget
Post by RR88 » Tue Oct 16, 2018 8:35 am
I removed some layers by a script and they are still visible in the layer list. How can I refresh/update the widget manually?
Arch Linux, QCad 3.22.0 Prof.
Re: Refresh a widget
Post by andrew » Tue Oct 16, 2018 9:00 am
If you remove the layers using RDeleteObjectOperation, the layer list will be updated. See RemoveLayer for an example:
https://github.com/qcad/qcad/blob/maste ... veLayer.js
RR88
Post by RR88 » Tue Oct 16, 2018 9:18 am
I found out, that it works only when I set undoable to true. Is there any workaround?
This is my code:
var op = new RDeleteObjectsOperation(false);
layers.forEach(function (name) {
    var lay = doc.queryLayer(name);
    op.deleteObject(lay);
di.applyOperation(op);
Post by andrew » Wed Oct 17, 2018 8:52 am
Making operations not undoable (argument false) means transactions are not recorded. However, the layer list and other widgets are rely on transactions to update themselves. Not undoable operations should only be used for offscreen documents that don't offer any form of user interaction at all.
RR88
Post by RR88 » Tue Oct 23, 2018 5:16 pm
Okay, thanks for the answer.
