Select multiple layers to remove and select multiple layers to remove
zadychladislav
Post by zadychladislav » Wed Nov 14, 2018 8:17 pm
Can you let me know where I can find :
Select multiple LAYERS to remove them all at once?
Select multiple BLOCK to remove them all at once?
Re: Select multiple layers to remove and select multiple layers to remove
Post by Husky » Wed Nov 14, 2018 9:38 pm
The current QCAD Version doesn't support multiple Layer or Block selection in either List.
May I ask you why you need this option?
