It is possible to decrease the width of a QPushButton, I tried with:
<property name = "geometry">
<Rect>
<Width> 21 </ width>
<Height> 21 </ height>
</ Rect>
</ Property>
but it did not work
Thank you also for the previous answer
reduce a button
- Full Member
- Location: http://creativitainformaticart.altervista.org
reduce a button
- Screenshot_20190926-085636_VNC Viewer.jpg (9.01 KiB) Viewed 5725 times
Re: reduce a button
The button might be in a layout in which case the layout controls the button size.
You should be able to override by setting size policy to fixed:
https://doc.qt.io/qt-5/qwidget.html#siz ... e-policies
- Full Member
Re: reduce a button
I tried that:
newIdObj3D = objectFromPath ("MainWindow :: Options :: NewIdObj3D");
//newIdObj3D.resize(21,21);
sizePolicy = QtGui.QSizePolicy (QtGui.QSizePolicy.Fixed, QtGui.QSizePolicy.Fixed);
newIdObj3D.setSizePolicy (sizePolicy);
newIdObj3D.clicked.connect (function () {presNewIdObj3D ();});
but am I probably wrong?
Re: reduce a button
Please have a look at PropertyEditor.js for an example to set the size policy.
Note that you can search the git repository online (for example for "QSizePolicy .js"). Or you can checkout the repository and search locally. QCAD sources contain lots of JS code with plenty of example code.
- Full Member
Re: reduce a button
ok thank you, I try to arrange myself as much as possible
solved this way:
<Item>
<widget class = "QPushButton" name = "NewIdObj3D">
<property name = "toolTip">
<string> Creates a new 3d shape </string>
</ Property>
<property name = "sizePolicy">
<sizepolicy hsizetype = "Maximum" vsizetype = "Fixed">
<Horstretch> 0 </ horstretch>
<Verstretch> 0 </ verstretch>
</ Sizepolicy>
</ Property>
<property name = "maximumSize">
<Size>
<Height> 16777215 </ height>
</ Size>
</ Property>
<property name = "text">
<String> + </ string>
</ Property>
</ Widget>
</ Item>
solved this way:
<Item>
</ Property>
</ Sizepolicy>
</ Property>
<Size>
</ Size>
</ Property>
</ Property>
</ Widget>
</ Item>
- Schermo.jpg (164.65 KiB) Viewed 5535 times
