Re: Inside Hatches, more than meets the eye
Posted: Fri Jan 17, 2020 10:30 am
BTW @1000000 Is as far as the Hatchkit guys go.
Their example is metric @25000000.
Correct form one point: 0,45,90,135... do not have decimals, so the don't loose any.
Solved & Explained !!
C++ double is a 64 bit IEEE 754 double precision Floating Point Number.John Hyslop wrote: ↑Fri Jan 17, 2020 11:40 amI have no idea, I don't do this sort of coding and because of that I
didn't understand Andrews answer to you..
I can not beat the used numerical system.John Hyslop wrote: ↑Fri Jan 17, 2020 11:40 amUnless maybe you can come up with a way to optimize the patterns
In that we agree, I think it would be a standard notice or even a default behavior when 'hatching'.John Hyslop wrote: ↑Mon Jan 20, 2020 12:49 amI think it might be a good idea to add a comment to users that hatch far away from the origin to edit the hatch properties to set the hatch origin back to X 0 Y 0
Thanks, maybe even clearer with this:
That it would be nice that this would be automated at the moment of generation I think I did mention somewhere.
Corrected the quoted a bit.
