I'm trying to add an Undo method to my program to correct errors made by the user in the construction of the 3D object, should I create a sort of log of the operations performed in order to possibly cancel them?
Currently it does not have a log of the operations performed
How best to make Undo?
- Full Member
- Location: http://creativitainformaticart.altervista.org
- Redo.svg
- (1.25 KiB) Downloaded 464 times
- Undo.svg
- (1.24 KiB) Downloaded 456 times
- OrthogonalProjections.js
- (107.15 KiB) Downloaded 451 times
- OrthogonalProjections.ui
- (16.8 KiB) Downloaded 462 times
Re: How best to make Undo?
If you are using operations (e.g. RAddObjectsOperation), undo / redo is automatically built in.
- Full Member
Thank you
I had used 3 starting at line 1837
in in line 1800
to cancel the 3 graphic representations in orthogonal projections of a 3D vertex
you mean in this sense?
But I don't think that the operations can operate on the multidimensional array that I made in which I save the 3D data, or am I wrong? (for example see line 1816)
A ... another thing how can I get the name of the path and the dwg / dxf file the user is working on? I thought of making a nearby file with the same name in which to save the data of the 3D entities under construction
I had used 3
op = new RModifyObjectsOperation ();
in
OrthogonalProjections.prototype.slotUndo = function () {
Operations keep track of the changes they make on a document. These changes can be undone / redone. If you change things other than the document, that is not covered.pietro_72_ wrote: ↑Tue Feb 11, 2020 12:06 amBut I don't think that the operations can operate on the multidimensional array that I made in which I save the 3D data, or am I wrong? (for example see line 1816)
doc.getFileName()A ... another thing how can I get the name of the path and the dwg / dxf file the user is working on? I thought of making a nearby file with the same name in which to save the data of the 3D entities under construction
- Full Member
OK thanks
