How To: Suspend drawing regeneration by script
Post by CVH » Mon Nov 30, 2020 5:50 am
Andrew,
Is there a way to suspend drawing regeneration by script?
Here: viewtopic.php?f=30&t=7842
Every individual move of a Hatch entity is followed by a delay that:
- is related to redraw the Hatch, even presumed: the whole drawing.
- the more there were moved the longer the delay. (Undocumented so far)
(QCAD is probably storing more and more undo information.)
I am aware that most of the delay originates from the hatch rendering.
(Setting these to solid reduces lagging tenfolds: https://qcad.org/bugtracker/index.php?d ... sk_id=2021)
It would be nice that I could suspend the regeneration of the drawing itself.
BUT without suspending List Widgets, ProgressBar and so on.
An off-screen document seems troublesome ...
... I already loose Blocks and entities in the original document for unknown reasons.
That's also a bit above my hat, any help welcome. :wink:
*EDIT* In the above Topic link the 13 failures are now documented.
