Deleted Entity still exists
RR88
Post by RR88 » Sat Oct 02, 2021 6:32 pm
I have another question.
I want to test, whether an entity has been deleted or not.
Here is the code:
var ent = doc.queryEntity(id);
var op = new RMixedOperation();
op.deleteObject(ent);
di.applyOperation(op);
var _ent = doc.queryEntity(id);
qDebug(_ent);
// RPolylineEntityPointer(0x54bb100)
Why is _ent not REntityPointer(0x0)?
I think, the reason is, that the entity still exists in history. Also isDeleted(_ent) is not true.
Arch Linux, QCad 3.22.0 Prof.
Re: Deleted Entity still exists
Post by andrew » Sat Oct 02, 2021 7:50 pm
Yes, deleted entities still exist for the sake of transaction handling (the undo / redo mechanism of QCAD).
You can check the status of an entity with entity.isUndone().
RR88
Post by RR88 » Sat Oct 02, 2021 8:01 pm
Thanks Andreas.
