Exploding splines
Posted: Fri Sep 28, 2012 9:20 pm
Hello all!
I use splines to draw things on my computer. But I need to send these drawings as lines entities to a CN machine.
So I use the explode command to pass from splines to polylines.
But on Qcad 3.0 (final release), splines have very few entities, and as a result, the CN machine is lacking precision for the cutting.
On Qcad 3.0RC releases, as well as Qcad 2, splines had far more entities when exploding splines.
As an example, try this:
I already searched how to tweak the spline tool script but no avail :/
My question is : Is there a way to add a setting to configure the number of segments for splines, as there was on Qcad 2?
Thank you for reading
See how many entities there are? Do the same with 3.0RC5 and compare.- Draw a rectangle starting from origin to @140,70
- Draw Spline (Control Points, shortcut SP), degree 2, closed using control points upper-left, upper-right, lower-right, lower-left then right-click to valid.
- Select that curve and explode (shortcut XP).
