Layer list window setup
J-J
Moderator
Post by J-J » Thu Mar 26, 2015 10:26 pm
Last November, there was this suggestion in the french section: http://www.ribbonsoft.com/rsforum/viewt ... =83&t=3137
I thought the idea was interesting, I keep my layer list on the right of the screen, it is a long way for the mouse to click the eye!
Any other comments from anyone on this ergonomic aspect of the layout?
JJ Win7 pro-64
Re: Layer list window setup
Post by andrew » Fri Mar 27, 2015 9:18 am
I like the current layout because the eyes and locks are in one column respectively. It's also possible that more columns will be added in the future. IMHO, adding all these columns before the layer name would look very awkward for layer hierarchies because of the different indentations. What do you think?
J-J
Moderator
Post by J-J » Fri Mar 27, 2015 11:57 am
you have a valid point, it was just a thought...
JJ Win7 pro-64
Tuttle
Post by Tuttle » Sun Apr 05, 2015 3:01 pm
So, can't we have a solution like that ? (without eyes in the right... Just icons after layer's name)
Sometimes, eye is very far away ! It's not easy to see... the good eye ! ;o)
Thank you !
Debian Jessie - 64 bits KDE environnement
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
Compiler : gcc 4.4.3
Tuttle
Post by Tuttle » Mon Apr 06, 2015 5:30 pm
Perhaps, another idea : alternating gray background ?
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
Post by andrew » Thu May 07, 2015 10:31 am
Post by andrew » Fri May 08, 2015 9:13 pm
This has been implemented as a user preference in QCAD 3.9.2.
Tuttle
Post by Tuttle » Thu May 21, 2015 7:37 am
Thank you very much !
I will download the lastest qcad version !
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
Tuttle
Post by Tuttle » Tue May 26, 2015 2:05 pm
For visitors, here are the steps to follow :
Result
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
