Print current view ...
Post by Husky » Fri May 15, 2015 8:46 am
I like the new "Print current view" feature in QCad 3.9.3 but the implemented automatic starts always the Printer Dialog. Right now I have to create ~35 pdf's and I need to close for each one the Printer dialog before I can start the pdf function. Thats simply annoying ...
Would it not make sense to keep it on the "usual" way and I can choose the output medium by myself in the option bar?
Re: Print current view ...
Post by andrew » Fri May 15, 2015 9:08 am
The idea behind this tool is to get the current view in model space printed out as quickly as possible.
For any other printout, please use the regular procedure: File > Print Preview, adjust scale, adjust position, File > Print.
