Reference Manual Not Found.
SaltyDoug
Post by SaltyDoug » Tue Feb 13, 2018 10:50 pm
I am running QCAD 3.12.4. I downloaded and installed the trial version of 3.19. Ive removed it but now when I click on Help>Reference Manual I see the following:
Is there a way to edit or restore a .plst file to get it working again?
Screen Shot 2018-02-13 at 1.41.39 PM.png (667.73 KiB) Viewed 1214 times
Thanks in advance.
Re: Reference Manual Not Found.
Post by Husky » Wed Feb 14, 2018 1:55 am
Has 3.19 overwritten the installation of 3.12.4? If yes please install 3.12.4 again in an empty directory.
Post by andrew » Mon Feb 19, 2018 10:39 am
You might have to remove the cache of the help tool. Delete directory:
"/Users/yourname/Library/Application Support/QCAD/ReferenceManual"
