Splitting polylines into parts with equal length
Post by Husky » Tue Sep 18, 2018 8:32 pm
Hi Andrew,
the new QCAD (3.21.3) update looks very good. It looks like you invested again a lot of time! Thank you for doing that for us!
Question: The "Split Entities" (MS) function is now able to split polylines too. I'm playing right now with it and see it doesn't works on closed shapes like rectangle, triangle etc.
I assume it works only on open polylines or do I miss something?
Re: Splitting polylines into parts with equal length
Post by andrew » Tue Sep 18, 2018 8:49 pm
Confirmed. You can convert logically closed polylines to open ones using Draw > Polylines > Logically Open Polylines, then split.
Post by andrew » Tue Sep 18, 2018 8:54 pm
Post by Husky » Wed Sep 19, 2018 12:58 am
Works. Thanks. :D
