Themes
mattT
Themes
Post by mattT » Sun Jan 20, 2019 4:09 pm
I have found the CSS for the QCAD theme in the files.
My issue is that I cannot see the increments on the rulers... They are Black on Dark Grey..! I have successfully changed the background, but found the increments seem to either be outlined or semi-transparent - I still cannot see them properly...!
What is the CSS to change this to something legible?
QCAD version: 3.22.0.0
Date: Jan 17 2019
Qt version: 5.12.0
Compiler version: gcc 8.2.1
Build Date: Jan 17 2019
Revision:
Architecture: x86_64
OS: Linux
Re: Themes
Post by andrew » Mon Jan 21, 2019 10:24 am
Can you post a screenshot? The ruler ticks should be white when the dark theme is used:
Schermafbeelding 2019-01-21 om 09.23.11.png (19.18 KiB) Viewed 3556 times
mattT
Re: Themes
Post by mattT » Tue Jan 22, 2019 4:43 pm
This is the default theme. I have altered the Dark theme too much.
Version:
3.22.0.0 (3.22.0)
Internet:
QCAD.org
Build Date:
Jan 17 2019
Revision:
Qt Version:
5.12.0
Architecture:
x86_64
Compiler:
gcc 8.2.1
mattT
Re: Themes
Post by mattT » Tue Jan 22, 2019 5:02 pm
OK - so I uninstalled via PAMAC and reinstalled via PAMAC
and the Dark theme does use white on black, it is still not easy to see though. What am I looking for to invert this within the CSS files.
