move w/o changing layer assignments
uflem
Post by uflem » Wed Sep 11, 2019 8:02 pm
I tried to move a selection of objects which were assigned to various layers. After the move, all were assigned to the currently active layer. How can I move, or more generally modify an object without changing its layer assignment to the active layer?
Thank you!
Re: move w/o changing layer assignments
Post by andrew » Wed Sep 11, 2019 8:05 pm
Please make sure the option "Use current layer and attributes" is unchecked in the move / copy dialog:
Screenshot 2019-09-11 at 21.04.10.png (72.93 KiB) Viewed 952 times
uflem
Post by uflem » Wed Sep 11, 2019 8:54 pm
Thank you!
