Snap to whole number coordinates
drbq
Post by drbq » Sat Aug 13, 2022 8:42 pm
Is it possible to snap to whole number coordinates? Grid snap works perfectly if I'm zoomed in at the level where grid spacing is 1. I'd like that behavior even when I zoom out and the grid rescales.
Thank you
QCAD Professional 3.27.6.0
MacOS 12.5 (21G72)
Re: Snap to whole number coordinates
Post by Husky » Sat Aug 13, 2022 9:19 pm
Would it help to turn off the grid scaling?
drbq
Post by drbq » Sun Aug 14, 2022 6:10 pm
I just tried, but it didn't seem to have any effect on snapping.
Post by Husky » Sun Aug 14, 2022 6:47 pm
Ok.
Most likly I didn't correctly understand what you are looking for. Please elaborate what means exactly
If possible with screenshots etc. Thanks.
drbq
Post by drbq » Sun Aug 14, 2022 8:09 pm
If the display is zoomed in so that the grid lines are at one unit increments, grid snap will make the cursor move at 1 unit increments across whole numbers. If I move the cursor horizontally, it will jump from (0,0) to (1,0) to (2,0) etc.
If I zoom out using grid snap, the cursor will skip whole numbers smaller than the grid increment -- moving from (0,0) to (10,0) to (20,0), etc.
If I zoom in, the cursor will include fractional coordinates -- moving from (0,0) to (0.1,0) to (0.2,0), etc.
I'm looking for a snap mode that will cause the cursor to move at one unit increments like the first example, but at any zoom level.
Post by Husky » Sun Aug 14, 2022 9:35 pm
Thanks for the explanation!
What are your Grid settings below Drawing Preferences.
Try this settings:
Post by CVH » Sun Aug 14, 2022 11:01 pm
Like Husky explained ...
It can be done with a fixed grid size and not auto-scaled, but there is a catch ...
What if you zoom out too far?
The display would be filled up with grid lines all spaced 1 unit apart.
Fortunately, QCAD prevents this and does not display a grid nor a meta grid at some point.
This is determined by the minimum grid spacing in pixels.
When it is not displayed, you can not snap to it. :wink:
Catch 22: When the grid spacing is beyond minimal no numbers are displayed anymore.
Even with the meta-grid is still visible.
Remark that Husky meta-grid is set to 12 for drawings in inch.
At a certain zoom level you might even get numbers like 0-2.4-4.8-7.2-9.6-12 but the grid would still be spaced 1 inch.
In a metric case I would set that to 10. :wink:
