dimension style - overall scale (or... how to confuse the user)
bambuko
Senior Member
Post by bambuko » Sat Sep 16, 2023 10:34 am
I can change Overall scale of individual dimensions by changing it's style properties.
Where do I change it as an overall setting for the drawing, please?
edit - just found it e_ugeek
it appears that in edit you need to modify:
Size scale factor
Am I correct?
and if yes, why two different terms for the same thing?
QCAD Professional
Version: 3.28.1.0 (3.28.1)
Internet: QCAD.org
Build Date: Mar 30 2023
Revision: ca7ec14
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
QCad Pro
Linux MX-21.3 "Wildflower"
Re: dimension style - overall scale (or... how to confuse the user)
Post by CVH » Sat Sep 16, 2023 6:14 pm
Size scale factor
Am I correct?
Correct ... And you might want to enter a request on bugtracker.
Edit .. Drawing Preferences for the current drawing.
Edit .. Application Preferences for all new drawings.
Per individual Dimension entity as Style override.
It's both about the Dimension Style .. Both are called Scale .. A scale is a factor .. The difference is the word 'Overall'.
bambuko
Senior Member
Post by bambuko » Sun Sep 17, 2023 6:24 am
well...
I see the difference as follows
(common in green, difference in red):
changing/override dimensions style in Property Editor (for individual dimensions):
Overall scale
setting dimension style in either
Drawing Preferences (for current drawing) or Application Preferences (for all new drawings)
Size scale factor
To be honest I am not fussed whether you use Overall or Size factor.
My suggestion is that whichever you decide to use
they should be the same for each of the three cases (individual dimension, current drawing or new drawings).
I will try to enter request on bug tracker...
QCad Pro
Post by CVH » Sun Feb 18, 2024 8:08 am
nora10,
nora10 wrote:
Sun Feb 18, 2024 7:13 am
How can I adjust the overall scale in the dimension style settings to ensure accurate measurements
What we debate here are the style setting of dimension entities.
Not the linear scale factor what is used to correct measurements in drawings made at scale.
I have to advice to draw in a certain scale.
Select a design unit and stick to it, draw everything in scale 1:1.
Form then on the unit doesn't matter, CAD is basically unit-less.
