Function Width, Length for polyline amd rectancles
Hello. I am an absolute beginner. I'm looking for a function where I can enter the length of a polyline or, for example, the height of a rectangle. It doesn't show up for me like it does on the interface of this tutorial (see appendix). Thank you for your help.
- IMG_1003.jpeg (122 KiB) Viewed 1249 times
Re: Function Width, Length for polyline amd rectancles
There is not really a method to actually set the length of a polyline.
For the required tool in the image see:
Menu Draw .. Shape .. Rectangle with Size (RS)
RS is the keyboard shortcut.
Simply hit the 'R' key briefly followed by the 'S' key.
See: https://www.ribbonsoft.com/archives/sho ... uts_en.pdf
Thank you very much!
