Re: Image Quality in DWG to BMP Conversion
Post by CVH » Mon Mar 11, 2024 9:11 am
Ushavilash wrote:
Mon Mar 11, 2024 8:37 am
Even after trying various settings, the BMP images aren't clear or high-resolution as expected
Not that I have experience with that ...
-antialiasing .... Enable antialiasing >> Less jagged lines when slanted ... Staircases
-quality=Q ...... Set the image quality / compression >> When using a image format other than BMP or TIFF
-resolution=R ... Set rendering resolution to R >> With for example 10 you get 10 pixels per drawing unit.
OR
-width=W ....... Set bitmap width to W (in pixels)
-height=H ....... Set bitmap height to H (in pixels) >> Will automatically compute resolution based on the extend of the window.
Remind that the output is limited to width*height = 536870911 pixels.
For a large drawings it might be necessary to increase the Lineweight of the art to export.
Unsure if Screen-based Linetypes or not influence the result ... :?
Post by CVH » Thu Mar 14, 2024 9:51 am
Seemingly user Ushavilash has left the building. :o
Initial post in topic has disappeared ...
The former post is/was a reply, the forum reports this now as a topic created by me ... :?:
Post by andrew » Thu Mar 14, 2024 9:53 am
Ushavilash was an AI-spammer. Unfortunately, an invasive species these days.
