Parts Library
ghh
Parts Library
Post by ghh » Mon Jul 29, 2024 2:56 am
Documentation says there is a large parts library. How do I access it?
New User
Re: Parts Library
Post by Husky » Mon Jul 29, 2024 4:13 am
Tutorial: Working with the Part Library
https://www.qcad.org/en/tutorial-workin ... rt-library
Re: Parts Library
Post by CVH » Mon Jul 29, 2024 9:14 am
That is not so 'large' by default, users may expect different things depending their field of interest.
Typically a user custom defines or collects parts based on custom needs.
Any snippet of a drawing or complete example drawing can be set aside as a reusable part.
Anything that can be imported can be considered as a library item, e.g.: DXF, DWG, SVG, PDF, bitmaps ...
In a standard installation I count:
- 27 DXF items
- 5 Script items
- 5 SVG items
In the link provided by Husky there are example links to online sources.
And a link to qcad-add-ons
At the bottom of that page there are part libraries including over 6000 parts and about 1300 SVG icons.
ghh
Re: Parts Library
Post by ghh » Tue Jul 30, 2024 3:08 am
Thank you
