JayPark wrote: ↑Mon Feb 03, 2025 8:38 am
I'm curious about how I can set the spacing according to my preference.
A circle its bounding box center equals its center. Cut/Copy without a reference.
Or you Cut/Copy a circle and define a reference point yourself. Cut/Copy with reference.
As said,
PE does not account for the overall size of the clipboard content.
If 2 circles must be spaced along a straight
Line entity by nnn then opt for the 'distance' method and enter (
nnn+diameter).
The distance between 2 circles will then be (
nnn+diameter)-radius-radius =
nnn.
This is NOT true for the same circles arranged along a curved entity or for every copy on a Polyline.
Because the repetition distance is measured along the curve ...
... The direct straight distance or chord between the centers is less (Arc, Circle) and may vary (Ellipse, Spline, Poyline).
=> Chord length is not equal to (
nnn+diameter).
=> The minimal distance between 2 circles is different from
nnn and may vary.
With not including endpoints the first copy of the clipboard will be place at
nnn along the line and so on.
Including endpoints, the first copy is placed at the start, the second
nnn from the start and so on.
Then an additional copy is placed on the endpoint and that may also fail
nnn from the second to last.
Perhaps it is easier to give an example of what to repeat equally spaced on what type of base entity.
For some things there are workarounds using regular polygons, auxiliary shapes, specific constructions and/or by using
FlexPainter.
