I am trying to make an isometric drawing of an circle.
When I try do draw an ellipse it asks for x and y radii and the angle.
I know the radius of the original circle and the angle, 30 degrees.
How do I calculate the x and y radii?
Thanks for the help, Rick
Drawing an Ellipse
Re: Drawing an Ellipse
may I ask you why you are not using the QCAD Isometric Projection tools below Menu: View > Top Projection etc ? To easy?
An isometric projection of a Circle, an Arc, is a bit more complex than a scaling factor.
It is an inscribed Ellipse in a quadrilateral or a part of such a full Ellipse.
For hand-drawing, project the axis-aligned square to isometric and draw an inscribed Ellipse (EQ) shape in that .
Crop that for an Arc at projected endpoints.
The angled cut of a circular object is also an Ellipse contour in the cutting plane.
Then it is the simple matter of scaling one of the radii.
