Reflect use Matrix transformation
duccoder
Post by duccoder » Mon Aug 03, 2015 5:00 am
Hi, I use QCAD Pro then I use Matrix Transformation tool.
I need use this to "reflect" entity. I use this matrix:
[-1 0]
[0 -1]
But when I type "D" = "A" = -1, QCAD force close. And I type "D" <> "A", it work
- Please help me why and how to pass "D" = "A"?
- And I need use this on my ECMAScript, but I can't find doc, it's script on `Pro` scripts folder
Re: Reflect use Matrix transformation
Post by andrew » Tue Aug 18, 2015 10:16 am
Thanks for your report. I've created a bug report at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1252
If you wish to rotate entities in your script, you can use the rotate functions of entities or vectors or flipHorizontal / flipVertical for [[-1,0][0,-1]].
Generic matrix transformations are significantly more complex since an entity might change its type (an arc might become an ellipse arc, etc.).
