Reloading script from command line
Posted: Tue Mar 15, 2016 8:14 pm
by ianbottomley
I know it is possible to reload scripts from the QCAD command line, without shutting down and restarting QCAD as I googled it and found it about a year ago ...
sadly no amount of googling has brought it to light this time
Ive tried every possible variation i can think of (reload, load, refresh etc etc) bit no joy
any offers please??
Ian B
Re: Reloading script from command line
Posted: Wed Mar 16, 2016 9:00 am
The command line argument you are looking for is -always-load-scripts:
./qcad -h
Usage: ./qcad [Options] [Files to open]
-allow-multiple-instances Don't try to avoid multiple instances from running
simultaneously.
-always-load-scripts Forces reloading of scripts when they are used.
This is mainly useful during script development,
to apply changes without restarting QCAD.
-app-id [ID] Set application ID. Multiple instances of the
same application (same ID) cannot run
simultaneously unless -allow-multiple-instances
is used.
-autostart [script file] Starts the given script file instead of the default
scripts/autostart.js. Note that with this option,
QCAD is not started but rather the application
implemented in the given script.
-config [path] Reads and stores settings to QCAD3.ini at the given
location instead of the default location.
-enable-script-debugger Enables the script debugger.
NOT recommended as this may cause unexpected
behavior when using QCAD.
-debug-action-order Print action oder information in menus
-exec [script file] [options] Executes the given script file directly
after staring QCAD. Options after the script
file are passed on to the script.
-gui-css-file [CSS file] Loads the specified CSS file.
-help Displays this help.
-locale [locale] Sets the locale to be used (overrides
the language set in the preferences).
E.g. '-locale de' starts QCAD in German.
-no-gui Don't use GUI. X11: don't connect to X11 server.
-no-show Use but don't display GUI.
-filter [filter] Opens the subsequent file(s) with the explicitly
given import filter.
-rescan Rescan scripts folder for new add-ons
-version Displays the application version.
-enable-xdata Enables XData (custom properties) support.
-quit Quits QCAD, for example after executing the
given script(s).
Mac OS X specific options:
-no-dock-icon Don't show icon in dock. This should only be used
in combination with -no-gui.
Posted: Wed Mar 16, 2016 9:59 am
by ianbottomley
Hi there thanks for that andrew - tried the -always-load-scripts switch previously but it doesnt do seem to do what it implies (scripts in libaray dont actually reload)
I found a command that could be run from the "Command:" prompt inside QCAD previously, something of the format "reload /path/script.js" but cant now find any reference to it, this allowed a script to be explicitly reloaded from the command prompt - and that seemed to work reliably.
Sadly can find no reference to it now.
Seem theres quite a large gap in the documentation when it comes to scripting and keyboard based interaction
any other offeres
Ian B.
Posted: Sun Jun 17, 2018 5:00 am
by J. F. van der Werf
It's two years later now and the problem of Ian Bottomley (Wed Mar 16, 2016 10:59 am) apparently has not been solved. Now i'm in the same kind of predicament: after opening a command screen, either as administrator or as 'guest', in the QCAD working directory, then typing <Qcad -h> yields no reaction; same for <qcad -help>, <qcad -version> and so on.
Trying: <qcad -always-load-scripts> starts qcad loading the scripts as found. However after minor changes in a script and invoking that script as per the menu system, the changed script is NOT reloaded. This renders the script development rather tiresome.
Also the somewhat loose usage of 'command line' which may refer to the command line in the qcad gui as well as to the cmd processor of the os, could confuse some users.
Jan.
Windows7, Windows 10, QCAD Ver.3.15.3
