Where are the digits on the rulers?
Posted: Mon Jul 11, 2016 5:56 am
by rfresh737
I have rulers turned on but they do not show any digits...all I see are tick marks...how do I get numbers to display so I know where my cursor is as I create objects? I move the mouse around the canvas but I don't any X,Y display telling me where I am on my canvas.
Re: Where are the digits on the rulers?
Posted: Mon Jul 11, 2016 7:32 am
Your drawing most likely uses an invalid unit / unit format combination. For example unit "Millimeter" and label format "Engineering" or "Architectural". Please adjust your drawing unit and label format under:
Edit > Drawing Preferences > General > Drawing Unit
Edit > Drawing Preferences > Dimension > Dimension Settings > Label Format > Linear Dimensions
Posted: Mon Jul 11, 2016 9:47 am
by Ramos
I also have the rulers turned on, drawing unit is millimeter, label format decimal and I don't have neither the ticks nor digits in the scale, just the triangular cursors.
Posted: Mon Jul 11, 2016 10:01 am
Please make sure that you check / modify the drawing preferences under Edit > Drawing Preferences (NOT the application preferences). Drawing preferences are for the current drawing, application preferences are default for new drawings and affect only newly created drawings.
If you cannot solve your problem, please attach your drawing file.
Posted: Mon Jul 11, 2016 2:33 pm
by Ramos
Posted: Mon Jul 11, 2016 2:40 pm
Please attach your QCAD3.ini file (~/.config/QCAD/QCAD3.ini), thanks.
Posted: Mon Jul 11, 2016 3:06 pm
by Ramos
Here we go.
Posted: Mon Jul 11, 2016 3:22 pm
I can confirm that the rulers are broken for your combination of preferences. The easiest workaround is to use default (and recommended) grid settings:
Edit > Application Preferences > Graphics View > Grid > [x] Automatically scale grid and [x] Automatically scale meta grid
Bug report added at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1445
Posted: Tue Jul 12, 2016 12:12 am
by Ramos
Thanks Andrew.
Could you pls take a look at my other question (Secondary Cursor), still without reply?
Don't get me wrong, as a long time user of the old AutoSketch, I am loving QCAd.
