I have set up a empty sheet with info such as layers set up the way I wish. But I am having problems understanding how to fit my drawing to this sheet and print it. I have read the manual, but being a bit thick headed I have not grasped how to do this.
Can you clarify this for me. Thanks
Caster
[solved] Fitting a dwg to std sheet size
Re: Fitting a dwg to std sheet size
Please refer to our detailed printing tutorial at:
http://www.qcad.org/rsforum/viewtopic.php?f=47&t=3317
Don't hesitate to post back here if that leaves any questions open you might have.
Thanks very much Andrew. This looks like the explanation I needed. I have printed it out and will be working with it tomorrow evening. In reading thru this info, I see it is based on info in the "tips and tutorial section". Briefly going thru this section I see much useful information for future study. I like this program a lot and am now able to make a very basic drawing fairly efficiently.
