Is there a way to focus on parameter entry without using the mouse? For example, I do a CR, then position my circle, and would like to type the radius without moving the mouse. It would be handy if there was a key to switch focus to the main parameter entry, or just that typing any numeric value would switch focus.
Oddly enough, typing a number seems to sometimes work, but mostly does nothing. Seems pretty random. This is not the latest QCAD, but 3.15.5 (linux).
Cheers,
Rob
Switch focus to command parameters
Re: Switch focus to command parameters
Either Ctrl-Space (see View > Focus on Options Toolbar) or simply starting to enter any number should indeed hand the keyboard focus on the first input field in the options toolbar.
Ah, I hadn't seen focus on options toolbar, thanks.
The auto-focus when a number is pressed doesn't work well at all though (3.16.5 and git). It seems that it works ok on a new sheet, until you cancel something. To reproduce on new sheet: CR5 <esc> <esc>. From now on CR<number> doesn't work anymore.
Wow, you are fast. Works OK now
