Break out manual
Always indicate operating system, QCAD version
Attach drawing files, screenshots
Post one question per topic
teegee
Break out manual
Post by teegee » Wed Mar 08, 2017 1:32 pm
Could it be that B2 is broken, or am I misunderstandng it? I'm not able to specify the second break point..
For example, in the attached example: B2, select circle 1, select point 2, try to select point 3. It keeps asking me for the second point (3.16.5, linux). What I would expect is the circle to be cut at points 2 and 3 (if remove segment is disabled).
b2.dxf
(100.11 KiB) Downloaded 199 times
Re: Break out manual
Post by andrew » Wed Mar 08, 2017 2:17 pm
teegee
Post by teegee » Wed Mar 08, 2017 3:49 pm
Thanks, fix works!
