How do I join a mulit page drawing into a single drawing. I am producing forms for a canoe, and need to print the form full scale. So I need to print it on multiple 8.5 X 11 sheets. I print with crop marks, but the drawing lines don't line up when I fit the pages together using the crop marks. I overlay one crop mark on the crop mark from the page to the left. Then the lines do not form a solid line but have gaps in them at the joint of the two papers. Am I doing something wrong or is this normal.
Stitch multi page drawing together
Re: Stitch multi page drawing together
A real size canoe? Sounds like you need a lot of Paper ...ov10fac wrote:How do I join a mulit page drawing into a single drawing. I am producing forms for a canoe, and need to print the form full scale. So I need to print it on multiple 8.5 X 11 sheets.
Unfortunately that sounds normal. The limit isn't caused by QCAD the limit is caused by your printer. Most likely your Printer isn't able to print to the very end of the paper size. Regardless the gab - the scale for the print is correct!ov10fac wrote:I overlay one crop mark on the crop mark from the page to the left. Then the lines do not form a solid line but have gaps in them at the joint of the two papers. Am I doing something wrong or is this normal.
BTW: If I work with multiple prints then I use a long Steel/Carpenter square and push Pins (for aligning the Crop Marks) before I glue them ...
If you cannot solve your problem, please attach your drawing file (DXF/DWG) and a PDF (File > PDF Export), thanks.
Thanks everyone. I followed Husky's suggestions and used a razor blade to trim the margin on some of the sheets. Now everything is fitting together pretty well. The crop marks seem to be a little off, but I think that's more the printer than Qcad. I should be within a few thousands and that should be good enough for my needs.
And yes it is a lot of paper, I have to print 8 forms, each a 3X3 sheet drawing. I can print them all on one sheet and then glue to foam board to reduce the paper and make my actual forms from that. I am still experimenting.
