[solved] Missing toolbar
Post by andrew » Mon Sep 18, 2017 2:24 pm
From a QCAD user:
After fiddling with the user interface, I have lost / floated a toolbar. How can I get it back?
Re: Missing toolbar
Post by andrew » Mon Sep 18, 2017 2:31 pm
You can move toolbars around by dragging them with the mouse. If you move a toolbar away from its original location to a place where normally no toolbars are (e.g. outside the application window), the toolbar becomes "floating". This means it is no longer attached to the main window but is shown in its own, separate little window:
Screen Shot 2017-09-18 at 14.30.14.png (43.54 KiB) Viewed 3300 times
It is also possible to close toolbars. In this case, they simply vanish.
To re-attach a floating toolbar, you can simply drag it back to its original location (or any other location near the border of the QCAD main window) to re-attach it.
To show a previously closed toolbar again, right click into any other toolbar and select the toolbar you want to show (for example Toolbars > View):
Screen Shot 2017-09-18 at 14.28.28.png (76.52 KiB) Viewed 3300 times
stef
Re: Missing toolbar
Post by stef » Thu Sep 21, 2017 5:37 pm
Hello Andrew ,
Thanks very much , problem solved !
Stef
