I am new in QCad, and I am using QCad 13.18.1 pro.
I have to add custom Context Menu for my dxf-files.
Is that possible, and if it is, how can I add it . Is there any example ?
Custom ContextMenu
Re: Custom ContextMenu
Hello dzenita - welcome to the forum.
Please give us more details about your goal. If possible with an example screenshot or drawing. Thanks.dzenita wrote:I have to add custom Context Menu for my dxf-files.
I am coding and I want do extend context menu in a script. Is that possible ?
I am writing company specific extension, and I want to put them inside right click menu.
In attachment is an example.
- example1.png (98.11 KiB) Viewed 4198 times
Please place this code in a file for example under scripts/Misc/Examples/CustomContextMenu/CustomContextMenu.js:
The code adds a custom entry "My Action" to the standard context menu of QCAD and should hopefully be self-explanatory.
include("scripts/Pro/Widgets/ContextMenu/ContextMenu.js");
function CustomContextMenu() {
CustomContextMenu.prototype = new Object();
CustomContextMenu.postInit = function(basePath) {
// disable default context menu:
ContextMenu.disconnect();
// initialize custom context menu:
var appWin = RMainWindowQt.getMainWindow();
appWin.contextMenu.connect(CustomContextMenu, "showContextMenu");
* This is called when user right clicks into empty space or on an entity.
* \param entityId ID of entity that was clicked (context) or RObject.INVALID_ID if
* context is empty space.
* \param pos Position of the click in drawing coordinates.
CustomContextMenu.showContextMenu = function(entityId, pos) {
// get the detault context menu from QCAD:
var menu = ContextMenu.getContextMenu(entityId, pos);
// add a custom action:
var action = menu.addAction("My Action");
action.triggered.connect(CustomContextMenu, "myAction");
// show context menu:
if (!isNull(menu) && !menu.isEmpty()) {
menu.exec(QCursor.pos());
* This is called when user clicks "My Action" in context menu.
CustomContextMenu.myAction = function() {
EAction.handleUserMessage("My Action Triggered");
Thanks a lot Andrew
It works
It works
