How to change the grab point of a Block
slyde
Post by slyde » Mon Dec 11, 2017 7:16 pm
Hi Forum:
I made a Block w/attributes last night. I want to change the grab point on it. I know I can explode it and create the block again and set a new grab point, but I'm worried abt losing the 30 attributes associated with the Block if I do that. What's the best way to do this?
Slyde
Look! It's a bird. No! It's a plane! NO! It's QCAD hotkeys...faster than a possum falling out of a tree!!
OS: Linux Mint 18.3 Sylvia [64-bit]
QCAD Pro 3.19.2.0 [64-bit]
Re: How to change the grab point of a Block
Post by andrew » Mon Dec 11, 2017 7:23 pm
The "grab point" of a block it its reference point. That's 0,0 of the block. You'd have to edit the block and move its contents.
Post by andrew » Mon Dec 11, 2017 7:25 pm
Hint: the only good reason to explode a block is if you don't want that part of the drawing to be structured as a block anymore. In all other cases double-click the block to edit its contents.
slyde
Post by slyde » Mon Dec 11, 2017 7:40 pm
Thank you very much, Andrew. I was afraid of losing the attributes. Now I know how to proceed without doing that. Thanks.
Slyde
slyde
Post by slyde » Mon Dec 11, 2017 7:47 pm
Piece of cake :D Thank you.
