[solved] Export section detail of drawing, for word processor
boldstripe
Post by boldstripe » Sun Jan 14, 2018 4:18 pm
I want to export just a detail of my drawing to insert on a page in a Microsoft Word document. I would like to export a vector format so that it does not make the Word document too big, while preserving quality/resolution.
I can get close to what I want by export or printing to PDF from QCad-Pro, choosing a single output page (A4 for example) and manipulating zoom to just fill that page size with the object(s) I need. However, by the time I insert that PDF in the Word document, it shrinks from, say, A4 wide to only ~150 mm wide, and the lines become too narrow to print well on my laser printer.
What is the best way to do this?
[Max OSX High Sierra, QCad-Pro 3.19.2]
Edit: it seems a bit better if I export PDF to an A6 page size.
Edit 2: changing the line weights to 0.13 mm (ISO), combined with the A6 page size landscape orientation, produced a pretty good result. The PDF can be set after Insert to 150 mm wide and the line weights printed well with my laser printer
Re: Export section detail of drawing, for word processor
Post by Husky » Sun Jan 14, 2018 6:22 pm
Hi boldstripe - welcome to the QCAD Forum.
boldstripe wrote:Edit: it seems a bit better if I export PDF to an A6 page size.
What's about to customize the pdf Page size ....
boldstripe
Post by boldstripe » Sun Jan 14, 2018 7:38 pm
Brilliant! (customize page size). Otherwise I was opening the A6 PDFs in Apple 'Preview' and using 'Crop' to get the best shape. Thank you!
Post by Husky » Sun Jan 14, 2018 8:17 pm
You're welcome.
