Select inserted image?
yetanotheruser
Post by yetanotheruser » Fri Mar 09, 2018 8:52 pm
Hi all,
I inserted an image using Draw - Insert Bitmap. Now I want to select it in order to resize it - but how can I do this? :?:
Just clicking on it does not work ):
Thanks!
Edit: OK, think I found it - had to make a rectangle selection around it. Is this the only way?
Re: Select inserted image?
Post by Husky » Fri Mar 09, 2018 9:07 pm
yetanotheruser wrote:Edit: OK, think I found it - had to make a rectangle selection around it. Is this the only way?
No, but it is sometimes challenging. You can use all applicable selection tools. If you like to use just a mouse click make sure you click close to the edge of the image.
