How to create text counting up
Andreas_FI
Post by Andreas_FI » Thu May 03, 2018 11:10 am
What would be the easiest way to create a list of text, names or labels that is counting up including a prefix or suffix?
This is a workflow I use quite often in my work when creating e.g. inputs labels from 1-32 (see example drawing attached).
Currently copy the text (in my example 32 times using move/copy command) and then change the text or number manually.
Is there a more elegant or effective way to do this?
Could I create a block with text and a field where a number or block count is automatically increasing when adding to a drawing or copying?
Thanks for your advice.
AW
Näyttökuva 2018-5-3 kello 12.52.04.png (264.88 KiB) Viewed 802 times
Re: How to create text counting up
Post by andrew » Thu May 03, 2018 11:14 am
Have a look at Misc > Draw > Counter which is somewhat unpolished (hence in Misc) but might cover your use case.
Andreas_FI
Post by Andreas_FI » Mon May 14, 2018 4:03 pm
Thanks Andrew. That would do the trick. At leasts it is more efficient than my current workflow. Thanks!
