Reference lines
Rantanplan7
Senior Member
Reference lines
Post by Rantanplan7 » Wed Jul 18, 2018 10:29 am
Hi everyone,
is there a special function for generating reference lines which will not be visible in a printout?
I would use constructions lines for that and would place them on a seperate layer which I would switch to invisible before I print it.
I assume that there is no quicker way?
Best Regards
Sven
QCAD 3.27.6.0 / Windows 11 Professional 64-bit / 16 GB RAM, i5 [email protected], SSD
(former Autosketch 10 user)
Re: Reference lines
Post by andrew » Wed Jul 18, 2018 10:55 am
You might just want to make that layer not plottable (edit layer and uncheck plottable in layer dialog). This means it shows up on screen but never gets printed.
Rantanplan7
Senior Member
Re: Reference lines
Post by Rantanplan7 » Wed Jul 18, 2018 12:35 pm
Sorry, but I have seen that layer function and tried it. Still visible in print preview. At the moment I don't have a printer connected so I can't double check if it is still in the printout.
Hopefully I have not found a bug?
Best Regards
Sven
Re: Reference lines
Post by andrew » Wed Jul 18, 2018 1:09 pm
These layers are visible in layouts / print preview. Only not printed / exported to PDF. You can test this with a PDF export..
Rantanplan7
Senior Member
Re: Reference lines
Post by Rantanplan7 » Wed Jul 18, 2018 1:17 pm
:P no bug. Works.
With this software you have done a really great job. I hope you are young enough to keep QCAD alive for many more years.
Best Regards
Sven
Re: Reference lines
Post by andrew » Wed Jul 18, 2018 9:05 pm
OK, good to hear it works. Thanks for the feedback!
