Hello out there
is there like kind of short way to merge end points, with a certain tolerance ?
in some way or another, some Points (or what are they called in this Incredible program?) didn t snap to each other
and may be will be a problem for cnc reading.. am in version 3.9.1
thanks a bunch in advance
merge endpoints
merge endpoints
- find unconnected2.png (96.97 KiB) Viewed 3374 times
- find unconnected1.png (100.48 KiB) Viewed 3374 times
Re: merge endpoints
the tool "Trim both" below Menu/Modify is perfect for cases like that.
Re: merge endpoints
am aware of that, but let say I have a drawing with hundreds of those areas...how can I determin them and
make those endpoints snap to eachother in a rather fast way?
Re: merge endpoints
Why would you have a drawing with hundreds of those areas? In an accurate created drawing would that be always an exceptional situation.
Re: merge endpoints
hahaha yes it is...
I just copied and pasted a lot....
in Blender 3D program you ve got an option to merge endpoints, so I thought maybe Qcad has a similar one..
Re: merge endpoints
Sounds like there was some kind of converting tool involved ....
No, QCAD doesn't has a tool which will fix that problem in one strike.
Re: merge endpoints
maybe because I ve drawn it in inkscape, exported to cqad this happened?
now I ve exported it into blender, repaired it there, and back to qcad, problem fixed...
maybe there s not really a need for this, but *remove doubles* can come in handy..
