Still struggling with borders
matt____jackson
Post by matt____jackson » Fri Jul 12, 2019 2:42 pm
I'm still struggling with the concept of how to insert a border around my drawing.
I've created a border with my company logo etc in a standalone dxf file. In my new drawings, I add this in from the Library Browser and it inserts it in a new block. Am I correct so far?
What I can't then get my head round is how this appears on my 'Layout1 (*Paper_Space). Do I insert a viewport to get it to appear? I see in the flange.dxf example that border is called a 'Block Reference' in the Property Editor?
QCAD-Pro v3.22.1 on MacOS.
Re: Still struggling with borders
Post by andrew » Fri Jul 12, 2019 2:57 pm
If you want to work with layouts and viewports, insert the border into the layout block, not into your main drawing (model space).
Please refer also to this tutorial:
https://qcad.org/en/tutorial-working-wi ... -viewports
You can also work without layouts and viewports:
https://qcad.org/en/tutorial-printing
-> Drawing Borders, Text Labels, Dimensions
matt____jackson
Post by matt____jackson » Fri Jul 12, 2019 4:32 pm
Thank you.
