qcad version 3.23.0 on mac and pc
Is there any way I can access the options, such as "keep original", in the move/copy command WITHOUT having to use the mouse, completely with the keyboard? I know I can turn off the dialog box, but then (for example) the move command is purely move, without copy. I'd like to be able to say "move the selected entity 10 units left, making 4 copies" without having to touch the mouse!
Thanks,
rick
Access "move/copy" options without the dialog box
red6rick
- Registered Member
Re: Access "move/copy" options without the dialog box
Hi rick - welcome to the QCAD forum.
I'll file a bug report to get it fixed ASAP.
Meanwhile you can use the dialog with the keyboard. To focus the keyboard to the dialog use CTR + space in Windows, navigation is typically (shift, space, arrow, enter etc) like any other Dialog navigation in Windows.
Yes, but my test showed that something isn't correct working.
Bug report filed below:
https://www.qcad.org/bugtracker/index.p ... sk_id=2014
