[solved] dxf to svg export
Post by Husky » Wed Jan 01, 2020 7:53 am
I've a dxf icon and need to export it to svg. The result looks ....... bad. What kind of entities can I use in the dxf to get a proper svg export? Or is it just a setting question?
dxf
svg result
Falling trees test.dxf
(107.41 KiB) Downloaded 146 times
BTW: Happy New Year! 8)
Re: dxf to svg export
Post by CVH » Wed Jan 01, 2020 9:32 am
Exploded blocks and used advanced SVG exporter.
and I get:
Falling trees test.svg
(3.04 KiB) Downloaded 164 times
Cheers,
Post by Husky » Wed Jan 01, 2020 6:49 pm
thanks - I tried that before - only partly working.
Post by CVH » Wed Jan 01, 2020 7:04 pm
Remark I'm still v23
Post by Husky » Thu Jan 02, 2020 8:10 am
I found my mistake - a Lineweight of 0.00 doesn't works for a proper svg export ... e_surprised
Re: [solved] dxf to svg export
Post by CVH » Thu Jan 02, 2020 8:42 am
The layer was set to 0.00
But I can't find any entity that uses the layer Lineweight.
All entities except the tree are polys with widths.
The tree is a hatch.
Besides that, why did the exploded export worked out.
It had the same weight and widths except I had no blocks.
Why it was in reddish is because it was selected while exporting to SVG.
What is a minor flaw. I step in this pitfall every time...
Says more about me... :P
It gets even better:
Without explosion, purely opened the file straight from the forum,
simply advanced SVG export workes out well.
Seems something changed between v23 - v24
Cheers,
Post by andrew » Tue Jan 07, 2020 9:50 am
