[SOLVED] Snapping in a Layout ... 2
Post by CVH » Sat Dec 05, 2020 8:19 am
Continued from:
https://qcad.org/rsforum/viewtopic.php?p=30695#p30695
Probably a Layer issue. :wink:
Husky already replied that.
But I also miss some snappers of a circle:
0° = ok (called 'Intersection')
Center = ok
On Entity = ok
The 4 called 'Reference' are missing ...
Maybe there are others ... :?:
Re: Snapping in a Layout ... 2
Post by Husky » Sat Dec 05, 2020 10:47 am
Center = ok
On Entity = ok
If you assume a bug please file a bug report below: https://www.qcad.org/bugtracker
Thanks.
Post by Husky » Mon Dec 07, 2020 1:49 am
Post by CVH » Mon Dec 07, 2020 6:24 am
Post by CVH » Mon Dec 07, 2020 11:01 am
@ Andrew,
Thanks for the quick fix
Marked it as [Solved]
Re: [SOLVED] Snapping in a Layout ... 2
Post by CVH » Tue Dec 22, 2020 9:00 am
Solved in Version: 3.25.2.7
Thanks Andrew.
