Rectangles & hatch
Posted: Fri Jan 08, 2021 9:09 am
Hi
After some of using QCAD there are 2 point I am not really happy with. That's why I want to ask what do I have to do different to make this work.
1. Rectangles- after drawing a rectangle is doesn't stay a rectangle but 4 exploded lines. Is there any way to keep rectangle as 1 'block'? I know I can use a PL but it's not so fast as using a rectangle.
2. Hatch. In AutoCAD of DraftSight there is an option to click into an are which is surrounded by the lines. I always found this way very fast. But in QCAD I always have to click al the lines (borders) which take sometimes long time.I know there are 2 ways to make hatching in QCAD but the 'easy' (using the selection) way is not working if for example the area which has to be hatched is created by blocks.
Can you help me please? Thanks.
