how do I create a pattern (array) of objects?
Krischu
Post by Krischu » Sun Feb 28, 2021 9:18 am
QCAD 3.25.2.0, macOS 11.2.2
How do I create a pattern of, say, squares?
I have created a square like 0,0;0,0 / 0,25;0,25 and would like to repeat it in Y with pitch 0,25 in Y.
To generalize it, repeat a pattern in x,y, nx,ny-times, with pitch px,py.
Christoph
Re: how do I create a pattern (array) of objects?
Post by Husky » Sun Feb 28, 2021 9:48 am
Create a block with this square,
select the block, chose insert,
chose in the option bar "Array of Blocks",
answer the questions in the dialog, ok, place the array in your Model_Space - done.
Krischu
Post by Krischu » Sun Feb 28, 2021 11:40 am
Select the block - OK
choose insert ? Where is Insert?
OK, I found Create Block from Selection.
I select a reference point and give the Block a name.
But Insert symbol (blue arrow down) is greyed out.
I got it working to some extent.
Christoph
