dwg2dwg: how to substitute ALL fonts with one?
bumsik-angelswing
Post by bumsik-angelswing » Sat Apr 17, 2021 7:59 am
Hi, I am currently trying to use dwg2dwg to fix the usage of fonts.
So I convert a font into another using the following command:
~/opt/qcad-3.26.1-pro-linux-x86_64/dwg2dwg -substitute=non_free_font:my_loyalty_free_font -o example_with_free_font.dxf example.dxf
How can I convert all fonts into one, such as:
~/opt/qcad-3.26.1-pro-linux-x86_64/dwg2dwg "-substitute=*:my_loyalty_free_font" -o example_with_free_font.dxf example.dxf
Using GUI, I kind of can do this because the GUI gives the list of fonts used in the file. But how can I do this in the command line tools?
Thanks!
Re: dwg2dwg: how to substitute ALL fonts with one?
Post by andrew » Thu Apr 22, 2021 7:07 am
This argument does not accept wildcards or regular expressions.
You could list the main fonts used in your file with:
dwg2csv -f -t Text -p "Font Name" myfile.dxf
Note that this will only list the main font of each text but not fonts that are used as part of the formatting.
For example if a text has its font name property set to "Arial" and the text contents is "ABC\fCourier|b0|i0|c0|p0;DEF", this command will list "Arial" but not "Courier". "Arial" is the font name property for the text whereas "Courier" is only used as part of its formatting.
Depending on the formatting used in your file(s), this might or might not be sufficient.
bumsik-angelswing
Post by bumsik-angelswing » Sun Apr 25, 2021 10:23 am
It works! Thank you for your reply!
