Dimension
Re: Dimension
Yes but I wouldn't recommended that: Explode the dim and delete the dimension lines.
- petevick
Re: Dimension
wouldn't that just be text ??
Pete Vickerstaff
Linux Mint 21.2 Cinnamon, Qcad Pro 3.29.4
Re: Dimension
Yes indeed, I think that the question should be which of the dimension lines should be omitted.
https://qcad.org/rsforum/viewtopic.php?t=9394
Re: Dimension
Nope. The last time I checked a dimension consists out of a Dimension Line, Extension Lines, Text and arrows or ticks.
- petevick
Re: Dimension
ok, so take away the dimension lines and you're left with text, extension lines and arrows/ticks, the extension lines and arrows/ticks are pretty useless in my opinion without dimension lines, so delete those and you're left with text. This is all my opinion obviously.
Pete Vickerstaff
