[solved] The dll file is missing
Certina
Post by Certina » Sun Aug 21, 2022 4:34 pm
Hello
I installed QCAD 32-bit.
During startup, it displays the following message: api-ms-win-crt-runtime-l1-1-0.dll error
How to fix it?
Regards
Re: The dll file is missing
Post by CVH » Sun Aug 21, 2022 7:07 pm
I searched for the string "api-ms-win-crt" on the forum and got some similar hits.
Maybe there is a solution for you in there too. :wink:
In general, first download the msi installer and then run it from where you saved it.
Make sure you don't have older versions or the CE version installed.
Certina
Post by Certina » Sun Aug 21, 2022 8:09 pm
Can you send a link to download the file ?.
Windows 7 Ultimate 32-bit version
Thank you.
Post by CVH » Sun Aug 21, 2022 8:22 pm
Certina,
You are posting on the QCAD Professional forum.
You should have recieved a link to your personal download area.
An msi or a zip file can be found there.
Certina
Post by Certina » Sun Aug 21, 2022 8:40 pm
Windows 7 is no longer being updated.
Thank you.
Post by Husky » Sun Aug 21, 2022 9:15 pm
Thank you.
Try a manual installation with the archive / zip file packet:
deinstall the msi version
Download the 32bit ZIP Archive from your download link,
extract the file to C:\Program Files,
this will create a new folder below Program Files. Folder name qcad-3.27.6-pro-win32
open this folder with FileExplorer (Windowsexplorer) and start QCAD with a double click on qcad.exe
if it works, create a shortcut to qcad.exe for a more convenient use.
Post by andrew » Mon Aug 22, 2022 8:34 am
Certina: Please install the Microsoft "Update for Universal C Runtime in Windows":
https://support.microsoft.com/en-us/top ... 7930f3560c
Please let me know if this does or does not fix the issue.
Certina
Post by Certina » Mon Aug 22, 2022 2:23 pm
Thank you.
I downloaded the indicated file, that is: Windows6.1-KB2999226-x86
I got the message: this update does not apply to this computer.
Post by andrew » Mon Aug 22, 2022 2:43 pm
Thanks.
Please install the "Visual C++ Redistributable for Visual Studio 2015":
https://www.microsoft.com/en-in/downloa ... x?id=48145
Certina
Post by Certina » Mon Aug 22, 2022 7:40 pm
Thanks.
Installation failed: 0x80240017 - unspecified error.
Post by andrew » Mon Aug 22, 2022 8:08 pm
Thanks. Unfortunately, I don't think QCAD can install or run on your system. Frankly, I think your Windows installation is fundamentally broken and should be set up from scratch.
Certina
Post by Certina » Tue Aug 23, 2022 2:38 pm
Thank you very much for your good intentions.
System Restore didn't help either.
I will have to reinstall the system.
Regards Certina
Certina
Post by Certina » Fri Aug 26, 2022 7:43 pm
Fixed.
It was enough to install the update: KB2999226
