Hi all, first post, be nice.
When I'm in print preview and I select the print button, the printer dialog opens up but I have no preview on the right hand side, this is happening on 2 PC's ,what do i need to do to get this working?
OS windows 11
QCAD 3.31.2
Thanks for any help
No Preview available
Re: No Preview available
This falls under 'No preview on (newer) Print Dialog'.
Similar explanation as here.
QCAD has it own preview method build in: See menu File .. Print Preview (Ctrl+Shift+P)
Also see the tutorial: Printing and PDF Export
john09cw
- Registered Member
Thanks for the reply, just starting to learn QCAD, defo better than Nano cad i was using before.
