When File References (xref) are not Bind or Insert,
As shown in the image below, an error will be generated if [Status] is set to ‘Not Found’, ‘Orphaned’, or ‘Loaded’ instead of ‘Opened’.
Thank you.
An error occurs if File References (xref) are not Bind or Insert.
swchoi
- File References (xref) are not Bind or Insert.png (18.61 KiB) Viewed 32550 times
Re: An error occurs if File References (xref) are not Bind or Insert.
QCAD does not support external references (XREF) at this point.
