Commands Do Not Start After Changing Layers in 3.30.0 PRO
RMK-Designs
Post by RMK-Designs » Sun Jun 16, 2024 3:46 pm
I am having a strange issue. After I draw an entity and then change layers, I must select an existing entity in the drawing window to activate the next command. For example, I select layer 1 and draw a square, exit that command, then select layer 2 and type PL for poly line nothing happens until clicking on the rectangle in the drawing area then type PL. Not sure if something changed from 3.29.6 but I have not had this issue before. I went back to 3.29.6 and all works as expected.
Thanks for any help. By the way I love the new toolbar tool options shortcuts!
I am using Qcad pro 3.30.0 on windows 11
Test.dwg
(16.84 KiB) Downloaded 275 times
Re: Commands Do Not Start After Changing Layers in 3.30.0 PRO
Post by CVH » Mon Jun 17, 2024 4:59 am
Seems to be a focus issue introduced in 3.30
After setting another layer active and a (few) clicks in the void on the drawing area I can reuse keyboard shortcuts.
Post by andrew » Mon Jun 17, 2024 7:59 am
Thank you for your report. Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2575
